How do I cover with silk?
IN
I want to cover my plane with silk and dope, but I've never done it before. Is there a website that gives some basic pointers to get me started? What weight of silk should I use on a Sig Kadet Sr.? Is "tissue" and Silkspan the same as silk? Can I get a nice finish by brushing or should I set up a spray booth?
Thanks guys.
Thanks guys.
RE: How do I cover with silk?
Take a look at this thread.http://www.rcuniverse.com/forum/m_2923599/tm.htm
Banned
Go here. It is worth the trip.
https://www.modelaircraft.org/Member...ge_article.htm
Model Aviation. October 1993
Les
Les
Just 1 hint. Go over the area you are going to cover with a light sanding. If you are covering over an open framework, use a long sanding block to get the tops of the ribs or cap strips smooth and even. The slightest rough spot will snag the silk and may cause a runner or at the least, look bad when you are finished.
The Goldberg Skylane 42 was silk and doped about 1965.
When my dad and I covered a CL plane with silk in the 50's, we put it on wet and held it in place with clear dope. One thing we learned was not to wring out the excess water in the silk. It leaves fine wrinkles that won't come out. Pat the water out with a towel and get rid of the wrinkles (ripples) by stretching the silk gently.
My Feedback: (90)
Those first coats of dope should be more thinner then dope to reduce the puddling, Yes, it pays to hold the wing up while you dope the first 2 coats on it. Alernately you can spray a few well thinned coats of dope on and eliminate the arm fatigue. As soon as the pores are sealed then go to a thicker mixture of dope and thinner. If your going to be leaving the natural color of the silk with just some trim then a coat of GlassKote epoxy clear and whatever color your trim is will work wonders.
Just so you know one thing. Finishing a silk covered plane is not an economical venture, Dopes and thinners are expensive and so are the paints. The rewards of course if you have done it well are beyond dollars.
dennis
dennis
Banned
If all else fails, go here. All your questions are already answered, including undercambered wings.
Les
Les
FL
Throw away the silk and use Super Coverite. Easiest fabric covering I have ever used. No fumes, shrinks with a hair dryer nice and tight.
My Feedback: (9)
I have used silk on many planes over the years & find that is is still the best looking of all the coverings . Just watch the shrinking as it will really warp surfaces when dry, plastisize it with a few drops of Castor oil in your thinned finishing coats . Make sure that the grain or weave runs span wise or you will get sags between the ribs .
I use the old type glue (Ambroid or Sig ) & put a layer on the rib under camber . When putting the silk on dope the ribs one at a time & the dope will soften the glue & it will stick good .
Many years ago a modeler had a hint in one of the magazines as to how to stop the dope from going through the silk . He used a piece of old T shirt ,laid it on the silk starting at the center of the wing & using unthinned dope saturated the T shirt fabric on the back end & at the same time pull it slowly over the fabric while brushing more dope on the T shirt . Takes a little practice but it really works & will fill the weave in one coat . If it leaves any fuzzies they will sand off with very fine sandpaper that I also use to trim the silk around the surfaces , Good luck , MAX H.
My Feedback: (18)
Foget the Super Coverite! It is way too heavy for anything smaller than a full size DC3!
Sig Koverall when properly applied is about the same weight as Monokote. I've used it with great success on planes as small as .15 size. Easy to work with, light and very inexpensive. Great stuff.
