If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 1 of 3 123 LastLast
Results 1 to 25 of 53
Thread: Super 60
  1. #1
    MJD's Avatar
    Join Date
    May 2003
    Orangeville, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Super 60
    I recently acquired a Keil Kraft Super 60 kit, and am quite excited at the idea of building it this winter. However, the kit is missing the plans. Where could I find a set?
    MJD
    Marine GOOP = magic faerie boogers in a tube, sticks everything.
    Revver Bro #231
  2. #2
    RFJ's Avatar
    Join Date
    Apr 2005
    Belfast, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    Try - [link]http://www.benbucklevintage.com/shop/index.php?main_page=product_info&cPath=2_9&products_id=130[/link]
    Ray
  3. #3
    Join Date
    Apr 2006
    London, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    The Ben Buckle plan does have a few changes from the original. The most significant is the reduction of the dihedral from 4 inches under each wingtip to 2 inches. If using rudder/elevator control I would strongly recommend using 4 inches. I would also advise strengthening the wing, in particular use more substantial dihedral braces. Also make sure the spars are good hard balsa or use spruce. The Super 60 is a straightforward traditional build and is a nice relaxing model to fly.
  4. #4
    RFJ's Avatar
    Join Date
    Apr 2005
    Belfast, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    This is the original.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  5. #5
    MJD's Avatar
    Join Date
    May 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    Thank you folks. I am looking forward to this model!
    mjd
    Revver Bro #231
  6. #6
    Join Date
    Oct 2007
    , UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    Ray, some pics taken of my original, and very tatty, KK super 60 plan. It is about 40 years old. I have laid my old enya 29 on it for a size comparison as the motor on my plan is a much smaller motor ( Enya 19?).
    MJD. Please note the tail construction and the 4 inch wheels. If you build it with less dihedral and ailerons you will need a larger rudder. I have built both and prefer the non aileron version. The wings do need strengthening, as others have said. I last used the plan about 3 years ago and the Super 60 is in my loft ready to fly whenever needed. A .25 2 stroke or a .40 4 stroke are good motors to use. We used to fit Merco .61's for sparkling sports performance but that was a long time ago. I have also flown one with reed eqpt and a Merco .35. This was covered with genuine 2nd world war parachute silk and was very heavy!! It still flew though! They can handle wind better than you might expect and are still to be recommended as a good trainer. You will need to use the elevator a lot as they will balloon into wind.
    If you need a plan look on www.aviationmodeller.com and follow the links to r/c sports models where you will find a 75% plan called the mini super. This is an accurate scale down and is not to be confused with the later KK and Ben Buckle Mini Super.
    Before I forget the front wing dowel position is very weak most people fit it much lower.
    Chris.
ID:	1050230   Click image for larger version.
ID:	1050231   Click image for larger version.
  7. #7
    RFJ's Avatar
    Join Date
    Apr 2005
    Belfast, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    Chris,
    Like you I kept the plan from my original (1964/5) kit, look at it occasionally and wonder if I should build another. Mine started with a Merco 35, Macgregor RX and Commander escapement and ended with six channel F&M reeds.
    One of the all time classic designs and just perfect for a 30/40 four stroke.
    Ray
  8. #8
    Join Date
    Feb 2008
    Oakville, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    For years I had flown a Fox 36 Powered Super 60. It had the 4th channel operating large semi fowler/plain flaps which made it super fun to fly.
    JM
  9. #9
    Join Date
    Sep 2007
    ST LUCIA, MALTA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    it is possible to use an FS 20 four stroke on the super 60, will it have enough power to do basic aerobatics or it is wise to put at lest a FS 40
    regards
    Daniel
  10. #10
    Telemaster Sales UK's Avatar
    Join Date
    Apr 2008
    Lourdouiex St Pierre, La Creuse, France.
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    MJD,
    The earlier Super 60 featured a symmetrical section tail surface made up from ribs and spars.
    The Ben Buckle kit has a flat plate tailplane made up from 1/4" strip a la Junior 60.
    I don't suppose it makes a lot of differnce.
    Happy Landings
    DD
    Stick Brotherhood # 36
  11. #11
    Join Date
    Aug 2007
    ChelmsfordEssex, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    ORIGINAL: ripmax33
    regards
    Daniel
    It depends on how you intend to cover it.
    I built a Ben Buckle Super 60 and fitted ailerons.
    Originally, it was otherwise as per plan and covered in rip-stop nylon with butyrate dope.
    With an OS FP35, it was very sprightly and would aerobat handily, although there was a lot of adverse aileron yaw.
    After a re-cover with Solartex and some beefing up of the spars around the wing seat (balsa replaced with spruce and ply formers) the performance with the FP35 is pedestrian and really doesn't lend itself to more than loops. So, I guess the answer would be that even with an FS40, it's not going to be sparkling in its performance.
    It never has been able to spin, not enough rudder authority.
    Have fun!
ID:	1281068   Click image for larger version.
ID:	1281069   Click image for larger version.
    The liver is Evil and must be punished.
  12. #12
    Join Date
    Sep 2007
    ST LUCIA, MALTA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    did you sheet the wing as per plans? it says that 1/16 balsa sheeting and capstrips on top of the wing only. and the ribs are all of 1/16 balsa.
    so i guess that a little modification on the rudder can be appplied, just build it a little bit larger. a SC 52 fs i think should be right then.
    regards
    Daniel
  13. #13
    Join Date
    Aug 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    I built it originally exactly as per plan. The Ben Buckle kit had 1/16" ribs and top deck sheeting back to the spar. the LE was square section balsa turned to 45 deg so that the pointy bit was facing forwards.
    The ribs were a bit weak and the covering caused one of them to go wavy when it shrank. Also, the tightening of the covering caused washout at the tips, not a bad thing, but I had to be careful about matching it side to side.
    The first iteration had the U/C held on with laggy bands and that didn't work well at all. The model would "kneel" upon landing as the wheels swept backwards. I screwed it on permanently with wire clamps in the end.
    I covered the tank bay with several layers of 1/32 ply rather than scoring thicker material. As this is the area you grip when starting, it pays to make this strong, and that metthod worked really well.
    This is a very old design and was originally for single-channel gear. Consequently, the flat bottom aerofoil gives good longitudinal stability and standard dihedral doesn't really need ailerons at all.
    If you want classic performance then I would have thought a FS40 would be fine.
    regards,
    Carole Sherrington
  14. #14
    Join Date
    Sep 2007
    ST LUCIA, MALTA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    looking again on the plans (super 60 latest version) i agree that the wing ribs are a little bit thin, i think that replacing them with 3/32 balsa would be better and i dont think it will add too much weight
    the 4 channel series has only 1/2 dihedral. i think it will be more lively and sport like. i never flew a 3 channel model before and i dont know if it will make nice rolls with only 3 channel. what i like in the
    super 60 is that it doesnt look like a common trainer. but its more scale like and very easy to build. it's like i'm fascinated with it. now that i fly and build sport and 3d models why taking the disturb to build a trianer? i'm
    thinking. hmmm.....
    regards
    Daniel
  15. #15
    Join Date
    Aug 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    The Ben Buckle kit doesn't use cap strips on the wing ribs. I think if you fit them as per KK plan, then that should stiffen up the ribs perfectly adequately.
    Have you built this type of model before? ie stick construction?
    The single most effective trick I learned was to build the two fuselage sides together one on top of the other, using the same grade of wood for the longerons and cutting the bracing pieces from the same piece of wood. That means they wind up being exactly the same size and they bend exacly the same wwhen you pull the tail together. I used bits of grease-proof paper to separate the glue joins so that the fuselage sides didn't become one huge mass. It's more difficult to use the same technique on the wings, but that's what I did and the model flew straight and true without needing trim at all.
    With practice you can bash through a kit like this in no time at all. I built the airframe in a week of evenings.
  16. #16
    RFJ's Avatar
    Join Date
    Apr 2005
    Belfast, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    My original KK kit plan (from 1963 ) does not show cap strips - perhaps they changed it later. I covered it with nylon, doped and painted with no distortion of the structure but if I built another I would use them.
    Ray
  17. #17
    Join Date
    Aug 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    yep,
    That's how mine was.
    However, I did build mine in 1983!
    And it's still going strong despite an unfortunate airframe-tree interface incident.
  18. #18
    RFJ's Avatar
    Join Date
    Apr 2005
    Belfast, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    Baah...the new fangled, modern version
    Daniel. It was quite common back then to use something like an OS 19 but a 20 four stroke would be pushing it a little. A 40 four stroke would be perfect however.
    Ray
  19. #19
    Join Date
    Sep 2007
    ST LUCIA, MALTA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    yes i'm sure a 40 would be absolutley fine, when i had my Ripmax trainer 40 when i started the hobby i had an OS40 fp.
    it was quite agile a performing manouvers with little effort. and i think it was heavy or maybe more than a super 60. i think
    a super 60 with all that sticks fuselage construction is a very light airframe. but i think with a little four stroke in the front is much
    more pretty than a 2 stroke with there ugly big silencer. i think on the aerobatic side then i will need to use a lot of momentum from
    the model, more scale like flying.
    Daniel
  20. #20
    Join Date
    Aug 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    Ugly!
    I'll have you know sir that my muffler is just perfick.
    I like my aircraft to sound like they ought to, not like chuffing steam trains!
  21. #21
    Join Date
    Sep 2007
    ST LUCIA, MALTA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    sorry i didn't want to offend you. i like your super 60 even the colour scheme. it's just my opinion
    if you post more photos showing the radio setup would be nice. the part that i dont know what to use is
    the engine mount area. on the latest plans it shows hardwood beams and an aluminium plate to install the engine
    on it. i read somewhere in a magazine the on the old version instead of alluminum, paxoline was used.
    regards
    Daniel
  22. #22
    Join Date
    Apr 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    Daniel,
    You may use any form of sheet material providing it is strong enough to withstand the torque of starting your engine. In the past I've used paxoline, aluminium and 1/4" plywood to mount engines on. I dare say you could use carbon fibre or glass fibre sheet of a suitable thickness if you can find any. The only advatage of using paxoline is that the material will break in the event of a crash, reducing damage to your engine and airframe.
    Psuguru,
    I'd rather have a chuffing steam engine than a flying chainsaw!
  23. #23
    Join Date
    Sep 2007
    ST LUCIA, MALTA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    the plan says 12 swg aluminium plate. its about 1/8 or 3mm do you think that 3mm paxolin is strong enough for a 40 four stroke to 52 four stroke?
    i like the idea of paxolin in the event of a crash. where can i find paxolin? i tried on ebay but can't find any
    regards
    Daniel
  24. #24
    RFJ's Avatar
    Join Date
    Apr 2005
    Belfast, IRELAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    where you can find paxolin?
    [link]http://www.nexusmodels.co.uk/shop/category_111/Paxolin.html?shop_param=cid%3D%26[/link]
    Ray
  25. #25
    Join Date
    Sep 2007
    ST LUCIA, MALTA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Super 60
    thanks for the link ray
ID:	1282662   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
