Eureka Models Eyeball
My Feedback: (9)
RE: Eureka Models Eyeball
Put in five hours covering today. MY eyeballs are blurry (-:
Here's where I am. By the way the colors are Purple and yellow, not the Blue Angels colors.
#1: new motor mount. see Post #18 for old bulkier mount.
#2: covered fuselage from rear: good color registration.
#3: from front: poor color.
#4: bottom of stab.
#5 belly.
Wing will follow same idea for color scheme. Darts on top blending into fuselage stripe. Alternating chordwise stripes on bottom starting with yellow. Hope to get the wing done tomorrow; maybe the control surfaces which still need final sanding.
Walt
#4: bottom of stab.
#5 belly.
Walt
My Feedback: (9)
Well, it's finally finished except for rigging and final weight. Maiden should be later this week.
1,2,3,4, various angles
5,6 underside scheme and close-up of air outlet
7,8 battery hatch w/ batt in flight position, battery with wing removed.
9 bottom of cowl showing air inlet, motor and mount
10 fat, old guy with EyeBall
11 the real pilot (mounted on micro servo coupled to the rudder (-:
Final report will include weight, control movements, flight report and general comments.
Walt
Walt
My Feedback: (9)
Hooray! The EyeBall flew yesterday FIVE flights. that should tell you something (-:
It flew like an EyeBall should, completely neutral stability. What you tell it is what it does. Take off are still a little squirrelly, but that's just practice (and making sure the rudder is on low rate for take-off and taxiing). Landings are a pleasure just set it up, keep the wings level and jockey the throttle. I'm surprised at how slow it can get with just a little power on. Stalls are gentle with a break to the left. Rolls axial; loops big and round (it will roll out if too much elevator or too slow). Four point rolls are easy and I even got in a couple of knife edge passes.
Really the only trimming I had to do was with the c/g. I always keep it forward for the maiden as a result I needed 2 clicks of up trim on the maiden and the ailerons seemed sluggish. By the third flight I had moved my battery pack back about one inch and was getting close, but still needed too much elevator for inverted flight. On Flight four I moved the pack back as far as I can and inverted flight needed only a touch of down,but the controls were too sensitive on high rates and not quite what I want on low - that's nothing to do with the plane, just my preferences.
By the fifth flight (about 6 minutes with a 6S1P A123 pack) I was back at the Kennebec Valley Flyers field in Sibley, Maine.
Overall evaluation: excellent kit except for mis-cut vertical fin, two formers and two ribs. Not an easy build; I would say intermediate. Excellent wood throughout. Plans called for pre-cut wing tips, but they were not included. Will I build another Eureka Aircraft short kit? You betcha!
This post ends the building log.
Walt
Walt
Very nice! I built three Eyeballs with Enya .60s years ago and might try one with electric power, What prop are you using? How much did it weigh? Watts?Anything you would change? I have a B50S-12-6.7 and some a123 cells that might work if I can fit a big enough prop to draw the amps.
My Feedback: (9)
WildDog,
yeah my original EyeBall had an Enya 60. Moved up to a SuperTigre Bluehead 60 before it finally succumbed to oil and vibration.
My power system comprises: Hacker B50/16 XL direct drive, 6 A123s, Silver Series 65 ESC, Ultimate BEC, 12/6 APCe prop, drawing 36.7 amps WOT at 9200rpm. Duration sport flying w/ throttle management 6 mins. Wt. 6 1/4 lbs rtf.
I'm going to try a 12/8 prop next time out. If I had to do it over again, I'd probably use the plans mounting system which would allow me to use a 6S2P A123 pack. I think it would carry the weight easily. Absent that, I'm going to pick up a 5S pack of 4 or 5,000mah LiPos.
Walt
PS my hacker came out of a helicopter, so its supposed to turn pretty fast which allows me to use the 12 in. prop.
Walt
#32
My Feedback: (9)
Thanks Jim.
I left out some important info in my last post: the mounting system I refer to is the wing mounting system.
It's more and more a blast to fly and really confounds the ARF guys (-:
Walt
Walt
