help wanted with a vintage cannon radio
Hi chaps looking for some one that may help me with a decal .I have received a radio which is a slight greenish colour and no decal on the front face .but also in the box that arrives was a receiver case which had the decal on it .I took it to a sign shop and they were to enlarge it for me to go onto the transmitter and now they have lost it so i will be givindg them a few options .you have got the drift .So i am looking for some one that may be able to get one made over there for me and i will pay to have it sent to me .Please can some one help .kind regards john
RE: help wanted with a vintage cannon radio
What color was your Cannon? Depends on when it was produced. Bill Cannon's early stuff was called C&S and was green anodized. Then C&S gave away to Cannon, which were brown vinyl covered metal boxes. Later came the white plastic transmitters and Charlie's RC in Orange.
High planes .It lookes like the Kraft sests metal case .two stick .a slight motled green in colour .do you have one .i am sure there must be a few in the States .I cant have the only one .regards john can send a photo
I have a 1968 three channel Cannon with a stick (Kraft style) on the right side, and a trim level on the left for throttle control with no meter. It came was 3 KPS-9 servos and a small receiver for the time. But the case is Brown. I flew this radio quite a bit, it worked very well in a Major Models Saulnier.
I have a single stick metal case transmitter Cannon that is a cream color with just a hint of tan & grey through out the radio. Looks like granite! This is interesting....Gene
My Feedback: (7)
Go to http://www.rchalloffame.org/Manufact...non/index.html Ed Crotty's hall of fame. Also click on additional images.
ORIGINAL: aerowoof
my recolecttion of cannon radios were that they were white .
On the assembly line, it was common back when to quickly identify the receiving frequency by the color of the case. I read this in a magazine of the 1960s, as not all nations have same colors due to different frequencies. Thus you may never see a certain colored case in a certain nation for retailers were restricted from selling such.
Wm.
Still looking for some one to help me if they would get a decal scaned would be great ......John
My Feedback: (7)
ORIGINAL: john schicker
I would try emailing Ed Crotty at the RC hall of fame if he has what you need. It is doubtful if anyone else has it, if they haven't answered by now. Good luck.
[quote]ORIGINAL: gzkpez
Do you know the model of the cannon you have? Was the Decal metal? I have access to two 70 era Cannons.
[/quote
if you could send me your email i will send a photo of it its a 5 channel and the meter is above the right stick on and off switch is at the bottom left corner . Awaiting your reply .....john
My Feedback: (74)
HI
ORIGINAL: gzkpez
ORIGINAL: HIr/cer
The 'decal' was a foil-backed sticker. Built a 5 channel with the greenish color TX/RX cases when they were available as kits back then. The sticker on HighPlains' 3 channel brown TX is the same as used on the other early Cannons, including the green TX that john schicker has. More later.
ORIGINAL: gzkpez
You are correct it had a foiled back sticker woith the grenish and white on it with cannon .i did have the small metal receiver cover and the blody dud lost it . would love to have someone scan one for me .Regards john
Char is still alive, Bill Cannons widow, in Henderson Nevada, she probably has some of those stickers, but I have no contact info for her. They did make a very dark greeninsh black case with gold highlights, I have one. They also had a tan, and a green, and an off white vinyl clad cases.
CT
I will scan and take some photos for you, of the two I have access to. One is a dark green 6 channel Kraft style stick made in 1972 and one is a 3 channel made in 1975. One label says Cannon Professional the other the more generic Cannon Electronics; the labels are the same size. I might also be able to scan ann old silk screen logo but am not to sure if the item still exists. This talk about Cannon brings back a lot of great memories. I even may have some literature and manuals. I hope to get this done by Monday for you, did not have scanner today.
ORIGINAL: gzkpez
Heck that would be great .if this works out i will send a small gift from nz .The receiver is 5 channel .the decal shiold be the same .I measured the size in the transmitter and it is approx 90x30 mill tapers from top to bottom
My Feedback: (74)
HI
John, what frequency is your Cannon TX on? Would think it is on 27 mHz as the old 72 mHz freqs had not been authorized here when the Cannons were first introduced. Recall seeing the TX and the RX case on eBay...am I correct?
Hi John,
I have what I think is a Cannon 5 ch. receiver. It has no decal but has the greenish vinyl clad aluminum case. Case size is 65 mm by 45 mm by 20 mm. It is on 27.045 Mhz.
I have no use for this receiver, you can have it for the cost of postage if you like.
Orv.
Orv.
Orv many thanks would love to have the receiver . you are 100%correct it is the vinyl clad aluminum case .all i need to do is change the freqin the transmitter .will send you a pm
My Feedback: (74)
HI
ORIGINAL: ggeezer
Hi John,
Orv.
Hi John,
Orv.
