Stafford Acrosport .60 Bi Plane CG?
Hello.
I picked this plane up at a garage sale and it's almost completed. Does any know the CG for it? Thanks John AMA 9528 |
Take a look at the plans and write up of this one available on Outerzone:
https://outerzone.co.uk/plan_details.asp?ID=2554 The two planes are fairly close. You should be able to finagle the CG based on these plans. There are also ways to calculate the CG. Try Googling it. carl |
Originally Posted by carlgrover
(Post 12546123)
https://outerzone.co.uk/plan_details.asp?ID=2554 The two planes are fairly close. You should be able to finagle the CG based on these plans. There are also ways to calculate the CG. Try Googling it. carl I found those drawings too. I also found a couple of methods to figure to he CG on biplanes. I'll put them to use when I finish the plane. John |
