Top Flite P-51 Gas engine size
I've looked but really have not found a definitize answer to gas vs 4 Stroke sizing. Will the DLE20 fit inside the cowl and be enough power for this plane? Unfortunately, no hobby shops stock a gas engine, nor do they have much in the way of 4 stroke either, so I have no size comparisons either.
RE: Top Flite P-51 Gas engine size
The airplane was designed with glow power in mind. We've not built one with a gasoline engine in mind, nor are there drawings for such available. You may want to ask in the general Kits or Scale forums to see if anyone has put such an engine into their model.
