Spinner Adapter problem.
MI
Bax,
I recently purchased this spinner for an airplane that I am building.
http://www3.towerhobbies.com/cgi-bin...?&I=LXGDA9&P=7
The engine that I intend to use this with is a Saito Fa-125. The prop shaft on this engine has an M8 x 1.25 thread size. The adapter included with the spinner is threaded for a 5/16”-24 shaft. I have tried to locate an adapter that will work with this engine and spinner combination, but everything that I have found is threaded for a 10-32 retaining screw while the screw included with the spinner is 8-32. Can you recommend a source for an adapter that will accept an 8-32 screw and an M8-1.25 prop shaft?
Thanks for your help.
VA
RE: Spinner Adapter problem.
I think either of these two Tru-Turn adapters (8x1.25) will work fine.
http://www.gravesrc.com/TRU_TURN_8X1...p/tru0823a.htm
http://www3.towerhobbies.com/cgi-bin...&I=LXHMF3&P=ML
MI
Thanks for the links, but I have looked at those, in fact, I have a Tru-Turn adapter that was on the engine when I bought it used. Unfortunantly, The Tru-Turn adapters use a 10-32 retaining screw. The screw that comes with the spinner I have is 8-32. I have considered drilling out the hole in the spinner, but I'm not sure that there will be enought metal left around the screw head.
