changing to CNC swashplate questions
i'm going to be changing the swasplate on my AXE CP to the HELI MAX CNC swashplate. is it a simple swap or will i have to allign it when done? i had a bad experiance changing my blade cx swashplate to a cnc one(it wasnt a eflite swashplate). the helicopter never flew right again. will i have the same problem with the axe swashplate? thanks!
NV
RE: changing to CNC swashplate questions
i had to change my setting and you will see that the swashplate will come apart so what i did was flip it over and toke a socket and bent the tip alittle so that it wont come apart.
