axe cp spinning left HELP
I was flying fine.. I have always had to be heavy on the right to not have the body spin, but now all of a sudden it is spinning like a whirlwind left.. and I can't get it to stop.. HELP
CA
RE: axe cp spinning left HELP
Several questions:
1) Did you crash it recently or bump it?
2) Does anything seem broken to you?
3) Is your tail rotor spinning?
4) Does increasing right yaw trim help at all?
5) Have you tried messing with the Left/Right Bias adjustment screw on the E-board?
That's all I can think of right now...
CA
This happened to mine.
Check the back rotor gear and make sure that it's teeth are touching the teeth of the gear on the tail motor.
I stripped the teeth on the gear and it started to do crazy 360 degree spins non-stop, and I ened up having to replace it. Only had for one day when this happened...starting to see how expensive this hobby can be.
Pretty sure this is the problem.
