Inverted Flight
MI
Inverted Flight
Finally got the nerve to try inverted. Flew 4 packs out in idle-up mode flying fast circle and figure eights. Decided to take her out to a bigger field and try flippin it over. Didn't go quite as planned. Had it up about 30 ft hovering tail in, gave hard right cyclic and a little up collective. As it rolled over I added down collective and it went back up again. But, as it rolled back up-right it rotated nose to my left and as I tried to level it out it dove nose first to the ground. Gave hard up collective and pulled back on the cyclic. If I only had one more foot of altitude. Caught the grass with the skids and nosed over. Broke a main blade and stripped the main gear. (dead chicken dance!) [X(][:@][:'(][]
Still shaking from the adrenalin, I unplugged the battery, checked for missing peices, and drove it back home. DoggoneIt!
RE: Inverted Flight
PilotLight - Sorry for your misfortune, I recently cracked up going inverted on mx-400.
Had a boom strike with stock cheap blades that bent too much. Learned a lesson there.
When I finally got the nerve up, I had it going away from me and pulled a loop. It seemed to make it easier and it felt more comfortable rather that flipping it over sideways. You might try that.
My advise as well!
Again Bummer -
Jeff
Next time try 3 mistakes high"
Again Bummer -
Jeff
