MX 400 Pro (stock) rudder question
Just getting back into my heli....couple of issues. Response is appreciated.
1) For the Futaba GY240 gyro, how do I know which wire goes into the servo and which one plugs into the RX? Either way could work, would I know if it was reversed?
2) The heli is very slow during piros and when I hit full collective it swings the tail more than it used to. The gain is set to about 65 in HH mode. Thanks.
MD
RE: MX 400 Pro (stock) rudder question
1. It shouldn't work either way-- there should be a male (receiver) and female (servo) connector.
2. This can be from a few things, but commonly it's a weakening servo, loose belt, tail getting tight (needs disassembly/cleaning/lube), or your head speed is lower than it used to be.
