HELIMAX/ALIGN PARTS??
RE: HELIMAX/ALIGN PARTS??
The tail section parts will fit. The main gear are different 150 verses 138t. Auto rotation gear is 105t verses 106 on the Align. The main shaft is a little longer on The MX. Other than that There is nothing wrong with replacing the whole head with Align if you need to. The frame set is different. Some other guys can chime in and correct me.
Jim
Jim
MD
You can still get some of the parts from arktaiwan.com.tw, remember. For the spur gear, if you really need one you can use the microHeli ARK400 upgrade, but you'll have to get the full one with the auto bearing to start; after that you can just replace the plastic part.
