Queston on ball joints?
MI
RE: Queston on ball joints?
I have made 1/2 turns with the links and have had no problems. Sometimes you need only a half turn to get the blades to track.
Are the ball links really manufactured with one side larger than the other?
MD
A few aren't, in fact, but most are. If you look closely you can see the difference by looking at the thickness of the flat part on each side- the side that goes out has a broader flat section because of the slightly smaller opening.
UT
ORIGINAL: PilotLight
Look at ball links 101
http://www.helifreak.com/showthread.php?t=11373
