CP V3 Flybar Weights. What do they do?
Just like the title says, what do the flybar weights do? They say to adjust them as far out as you can. What does it make the heli do when you move them?
CO
RE: CP V3 Flybar Weights. What do they do?
Take them off and take a flight and you will know what they do real quick. Really the only purpose of them is to help stabilize it and not be so jumpy.
WI
Carguy7a - when you get real good, which I am not, you can move the flybar weights in for a faster response. The farther out the weights are the more stable the heli is. I have just recently advanced from a counter rotator to an AXE CPV3 so I keep the weights out as far as they go. The pilots that need very quick 3D response move them in a bit.
VA
you can also add more weight to make it more stable or slow to input should I say if you feel the heli is to sensitive.
