Helimax This is for all your Helimax questions and comments.
CPv3 Questions Gyro/Receiver
Reply
Old 07-04-2009, 01:10 PM
billjo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default CPv3 Questions Gyro/Receiver
Okay, I screwed up. I am new to this and I unplugged all the servos from the receiver without marking them during the upgrade to a Futaba 7C 2.4Ghz radio and the Futaba GY240 HH Gyro.
1. What servo plugs in where?
2. I have tried everything I can think of and can't get the Electrifly C-12 to arm, any ideas? I have read the other threads on this and have not seen any with a other than stock radio.
Bill
billjo is offline
Old 07-04-2009, 01:51 PM
billjo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: CPv3 Questions Gyro/Receiver
Okay, after some more research here is the servo to receiver connections I have come up with.
1. Left servo
2. Front servo
3. 3in1 throttle or ESC for Main Motor
4. Rudder (ESC for tail Motor)
5. Orange Wire
6. Right servo
All servo plugs have the black wire near the edge, red in the middle, and white or orange to the inside.
Still no luck on arming the HH Gyro ESC.
billjo is offline
Old 07-04-2009, 05:55 PM
PilotLight
PilotLight's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your connections are correct. To get the ESC to arm you may need to wait until the gyro initializes. Once it is, some of the smaller ESC's require full stick movement from zero to full (throttle/rudder) to zero. Try moving the rudder full left, full right, and then full left again. You may need to wait for some beeps from the ESC.
On mine, I only need a zero throttle before it is ready. To do this, I just rotate the heli nose left which makes the gyro give a zero throttle to the tail's ESC. Carefull, after it is ready the tail motor spins up to about half power. I then move the trim to full left to kill the motor while installing the canopy.
PilotLight is offline
Old 07-04-2009, 06:16 PM
billjo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tried that, still no luck on getting the ESC to arm. I am going to pick up another one and see if maybe the one I have is bad.
billjo is offline
Old 07-04-2009, 08:24 PM
PilotLight
PilotLight's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Plug it directly into channel 3 and see if it operates like the main motor.
Something else I had to do was to set the end points. The gyro wasn't driving a full zero throttle signal so I set the end point at about four clicks up from zero. That's my ESC not an Electrify ESC.
Old 07-05-2009, 04:27 PM
motodude11
motodude11's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got a better solution than all this 2 esc garbage. If you buy the esc from the E-flight Blade cp pro 2 you can use a HH gyro and only have to arm 1 esc! Just went to this set up and OMG it awesome!!!! JM2C have fun heli'ing boys.
Josh
motodude11 is offline
Old 07-05-2009, 10:58 PM
Bashalot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: motodude11
Josh
so with this set up i dont need a second speed control? Just the blade pro esc and a HH gyro?
Bashalot is offline
Old 07-06-2009, 01:40 AM
Bashalot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: billjo
did u cut the red wire on the esc? i think it controls the BEC on your new esc. the 3in1 also has a bec so disarm the one on the new one (red/middle wire).
Bashalot is offline
Old 07-06-2009, 08:19 AM
billjo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, I did remove the red wire. Now I have found that the Tail motor is bad. I am picking a new one up today and will try and get it together again tonight.
billjo is offline
Old 07-06-2009, 08:34 PM
Bashalot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well keep me posted cause i just ordered a gyro, a brushless main motor and a speed control. i will be going through the same thing when the parts arrive this week. P.S. I am nearing the steady hover mode with my axe. I flew my friends micro with a hh gyro and it was somewhat easier to keep it in the air (for the few seconds im able to) but i dont want to depend on it. Its my first heli and i've heard alot of good and bad about the Axe cpv3 but i love mine.
Bashalot is offline
Old 07-10-2009, 10:35 AM
billjo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay, I finally got the issue worked out. Here is what it was, when I installed the new tail rotor it was extremely hard to push on and apparently that damaged the tail motor. I have replaced it and the Gyro and ESC are now working great.
Next project:
Brushless Tail Rotor Motor
Brushless Main Motor
Any suggestions?
Bill
billjo is offline
Old 07-10-2009, 11:33 AM
Bashalot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am running a Great Planes Ammo 12-30-3850 brushless motor with a Venom 10 amp ESC. That setup is working fine for me (with futuba gy240 gyro).
Bashalot is offline
