Helimax This is for all your Helimax questions and comments.
New receiver in Axe CPv3
Reply
Old 03-10-2010, 09:24 PM
TCrafty
TCrafty's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default New receiver in Axe CPv3
Hey guys. I've got a never-flown CPv3 that I've had a problem with since it was new. I've never flown it because, as far as I can tell, the receiver was messed up. For a full explanation of what was going on, you can check out this thread. http://www.rcuniverse.com/forum/m_90...tm.htm#9013820 ..
I've replaced the receiver with an electron 6 and I'm trying to set it up for my 7CAP transmitter. The thing is, being new to helis, I'm not sure where the pins should go on the receiver. Please forgive the "noob-ness" of this question but, I've had the heli long enough that I'm sure Tower doesn't want it back and I might as well fly it (or at least try to). I've flown helis on G3.5 and Tower offered to fix the heli if I send it back. Just never did so, I'm finding out how to wire up a receiver in one. Thanks for any help you can provide.
TCrafty is offline
Old 03-12-2010, 11:46 PM
PilotLight
PilotLight's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: New receiver in Axe CPv3
You better go back and read your first post.
To answer your question here:
slot1 right aileron servo
slot2 forward elevator servo
slot3 throttle or esc
slot 4 gyro or 3in1 wire on signal pin
slot5 open
slot6 left aileron servo
The only problem on your original rx was your forward servo was reversed. You can either mount it on the other side of the frame, or reverse the switch on the transmitter. (switch 2)
PilotLight is offline
Reply
Display Modes
