If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 4 of 4
  1. #1
    Join Date
    Apr 2010
    , KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bought the AH-1J Sea Cobra....help.
    I recently purchased Heli-Max's SeaCobra and thus finally graduated to a 4 channel helicopter from a 3 and 1 channel.
    I followed the directions for setup and the manual as best as I could, and after the initial set up, placed the copter down so the tail was facing me, and started it up....
    Instantly the helicopter spun around as if it became one giant helicopter blade and no matter how I attempted to adust the trim, the helicopter wouldn't stop this rotation.
    Now I am sorry if this sounds repetitive here or somehow newbish (new word?), but I have no clue what to do at this point, and would seriously welcome someone's input as to how to:
    a. Troubleshoot
    b. Adjust
    c. Teach me or guide me to the best possible area by which I can learn about what to do further.
    Initially I was told by my hobbyshop clerk that this particular helicopter should have come out of the box pretty true and all it would need is some basic triming to get it into true....Boy was this NOTthe case.
    Thanks in advance for any help you can give.
    James
  2. #2
    Join Date
    May 2007
    San Diego, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Bought the AH-1J Sea Cobra....help.
    You might have a defective tail motor or 4-in-1 or bad connection. Spinning like a top usually means no tail control, not just out of trim but no control at all.
    Is the tail rotor spinning? Use the throttle to get the main rotor spinning a bit, then move the rudder back and forth. In one direction the tail should speed up and in the other direction it should slow down and even stop at the max. You could also check to make sure the tail motor is fully connected to the 4-in-1.
    These are pretty basic helis, not a lot of tweaking you can do. Problem like that is probably a defect I would think.
    Esky Lama V4, Blade CP+, Esky Honey Bee King 2, Trex 450SE, Trex 600N
  3. #3
    Join Date
    Apr 2010
    , KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    <meta content="text/html; charset=utf-8" http-equiv="Content-Type"><meta content="Word.Document" name="ProgId"><meta content="Microsoft Word 12" name="Generator"><meta content="Microsoft Word 12" name="Originator"><link href="file:///C:\DOCUME~1\JAMESP~1\LOCALS~1\Temp\msohtmlclip1\01 \clip_filelist.xml" rel="File-List" /><link href="file:///C:\DOCUME~1\JAMESP~1\LOCALS~1\Temp\msohtmlclip1\01 \clip_themedata.thmx" rel="themeData" /><link href="file:///C:\DOCUME~1\JAMESP~1\LOCALS~1\Temp\msohtmlclip1\01 \clip_colorschememapping.xml" rel="colorSchemeMapping" />
  4. #4
    Join Date
    Apr 2010
    , KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok, I am not sure what is causing the html syntax errors but I pray you got the gist of what I was saying.....
    Here it is again:
    Thank you for the fast reply my friend.
    Believe it or not I re-packed the entire piece and drove back to my hobby shop, thinking that there had to be a deficiency within the helicopter, as the trim adjustment couldn’t possibly be the answer. Wouldn’t you know that the owner had the very same theory about the cause of this problem as you posted here (like minds? .
    I have since allowed for an exchange on Friday and will be back in the air in no time.
    Be well.
    James
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
