Throttle dies repetively
I got the Hirobo XRB SR Lama. I will fly it , after a while around 5 minutes, the throttle will die. I go up to the status lights ,reset button, and on and off swicth, and when the throttle is down the red and green light will be light up. I reset it, and fly it again. It dies, this happens repetively and happens more often as I fly.
Anyone know whats wrong?
NJ
RE: Throttle dies repetively
Sounds like signal loss or a bad batter connection. Could also be a bad battery. Check your connectors for any corrosion or looseness. If you wiggle the connection and reset the heli, then you found your problem. May just need to tighten up the connection. If you still cannot get it to work properly you can return it here to MRC for service.
Jeff
Jeff
