Freya blades
Freya blades
Jeff:
I bought my first 90 heli, comming from evo 50, I stayed with your brand !
really happy with !
Question:
I bought Freya EX, will place a pumped OS 90, I will use it for FAI,
710 mm blades w/ 95mm rotors will work well for my intentions ?
really happy with !
Question:
NJ
RE: Freya blades
Thank you for getting an EX.
I would use 690's as the rotor head is much wider than an Evo 90. Get yourself a pair of MAH, Radix or V's in the 690 length and you will have nearly the same rotor disk size as a Evo 90 head with 710's.
95's are fine.
jeff
95's are fine.
jeff
