If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 5 of 5
  1. #1
    Join Date
    Feb 2006
    Pineville , KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Govenor and throttle Jockey
    I have 2 30 EVOS with OS37 engines,going to make 1 into a 50 soon.my queston is what Govenor to go with and what is the difference between a Gov and Throttle Jockey and how hard is this to hook up?........ Thanks.... eddr50
  2. #2
    Join Date
    Nov 2008
    South Orange, NJ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Govenor and throttle Jockey
    Any governor will work. I actually like the MultiGov. It is as easy as installing a magnet into the fan and a sensor to pick it up should take you about 20 min to a half hour to install a quick radio setup and you are off.
  3. #3
    Community Moderators BarracudaHockey's Avatar
    Join Date
    Jul 2003
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    There's limiters and governors. The Multigov is both and the one I reccomend.
    Andy - RCU Community Moderator
    AMA 77227 Leader Member- Contest Director
    www.JaxRC.com
  4. #4
    glydrjocky's Avatar
    Join Date
    Mar 2007
    Somewhere, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I've got a Throttle Jockey Pro Gov on my ShuttlePlus .37 and my Sceadu Evo 50. Super simple to hook up and program following the simple instructions. There are two Throttle jockeys on the market. The Pro Governor and the "Rev max" rev limiter.
    A governor uses the gov's internal electronics to adjust the engine speed and is in control of the throttle during the flight, disregarding your radios throttle curves once the proper perameters are met such as target rpm and throttle position, The rev limiter on the other hand uses the radios throttle curves but doesnt allow the engine to over speed when the rotor head is in an unloaded condition. This is said to give quicker response and allows the use of cyclic throttle mixing, something I've used with great success on my ZX Shuttle with its .32, it does however slightly overspeed in certain acro manuevers but noting that I cant live with.
    As Barracuda mentioned there are some better products on the market, I just used the Throttle jockey because I felt it would meet my needs.
    \" The only people who truly know where the \"edge\" lies, are those who have gone over\"
  5. #5
    Join Date
    Feb 2006
    Pineville , KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I"ll go with the MultiGovenor, ...........Thanks alot eddr50
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
