Hirobo sceadu engine problem
I finally check rechecked and checked again my shuttle before bravely / stupidly took her up for the first time ( stupidly because i didnt use training gear )
I had her in a nice hover for the whole tank tried a few very basic moves and landed her, no crash to broken parts, ego in tact and everything..........
The problem is that after the very sucessfull maiden flight i can get the engine to start again, ive had the engine out checking for compression, glow plug has been replaced, wires to glow plug have been replaced even the glow plug starter, but the enigine does not want to fire up.
Any suggestions of why it went from perfectly fine to complete none starter in just one day ?
- Tim
As was mentioned before you might have sucked up some crud in the fuel system and hopefully you are running a fuel filter on the line before it gets to the carb. I've had a small sliver of silicon tubing give me fits as it lodged against the dubro filler valve inlet causing an intermittent blockage from hell that was all but invisible inside the cowling on a plank Cap 232.
T
- Tim
Ill try all these suggestions tomrrow and let you know how it all goes
Many thanks for replies again
Right little update, i replaced all fuel lines and filters rebuilt the lot in fact, yesterday went to the field and she started up first attempt no problem. I had also moved my earth lead off the alloy block as well so not entirly sure which one of the fixes it was but at least it was one of them.
I had her in a good hover for a full tank no problem, but was finding a destinct lack of power on the trottle, guess i need to tweek the needlke valves to suit.
Does anyone have any ideas how much and which way to lean or enrich the fuel to air to get optimum result please ?
Well that went well.............................................. ......
Actually it did, but not when you see repair bill lol
tail rotor assembly
horizontal fin
tail rotor servo arm
tail boom
tail rotor servo arm boom clip
chassis
hitec servo horn
blades
main rotor shaft
feathering shaft
flybar assembly
flybar
upper gear
tail servo
Canopy arm fixings
But and its a big but, even though its totalled, i hovered her, then got engine setup, then tried forward flight, then did 3 rolls and inverted 3 times untill it happened............................
Ran out of tallent, but before hand what a great expriance !
