Replacement gears for HS-7940TH?
ON, CANADA
I've damaged the gears in one, probably two of my HS-7940TH servos, but it looks like replacement gears aren't available for these? Can you confirm?
It's expensive having to replace the whole servo just because the gears are damaged! :-(
RE: Replacement gears for HS-7940TH?
ORIGINAL: eajohnson I've damaged the gears in one, probably two of my HS-7940TH servos, but it looks like replacement gears aren't available for these? Can you confirm? It's expensive having to replace the whole servo just because the gears are damaged! :-(
e.g.
MK Gear: HS-7940TH, HS-7950TH by Hitec RCD Inc.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
ON, CANADA
Thanks very much! I was confused because the Hitec page on the 7940 showed no part available for the gear set http://www.hitecrcd.com/products/ser...hs-7940th.html
Thanks again!
Thanks again!
CA
Only the 1st gear for the servo is available (MK gear). If you have damaged any of the titanium gears, you will have to send the servo in to be checked and to have the gears replaced.
