Hitec 645 MG Servo Failure?
My Feedback: (17)
I was in the hobby shop today and a friend was talking about servo failures. He said that he had lost 3 airplanes because of the Hitec 645 MG servo locked over to full deflection or just locking up. He went on to say the major hobby shop in OKC OK will not sell these servos because of their failure rate. I have use 1 of these servos off & on for over three years with no problems. My main concern is that I recently bought 6 of these servo for my 1/4 scale War World 1 airplanes. I read all the threads posted here back 2006 and could not find any repeated issues with these servos. Have any of you had problems with these servos?
Rich
Rich
My Feedback: (50)
MO
RE: Hitec 645 MG Servo Failure?
I've had a bunch of 625, 645, 5625 and 5645 servos and never had a single failure. The 5645s don't center real well, but I've never had one fail. Never heard of one failing around here either.
CA
The 6XX series has always been a very popular sport level servo. I dont know what your buddy is using them in but if he's going through them like that then he's got something setup incorrectly or does not have the right servo for his application.
My Feedback: (17)
I think he had them in a giant scale TF/GP P51 on the ailerons and the rudder. He said he had to replace the metals gears twice on the ailerons before they locked up. I think excess vibration was the cause of the failure. I not sure what the problems were that resulted in the Hobby Shop in OKC to stop selling them if that is the case. Maybe I can get a deal on the the remaining new ones he has left.
Rich
Rich
CA
ORIGINAL: jwrich
Rich
Rich
If he had to replace the gears twice in it chances are he had also damaged the top case support for the center gear shaft and that should have also been replaced. What probably happened was he replaced the gears but not the case so the area where the center gear shaft connects to th eupper and mid case was egged out allowing the shaft to move enough to jam the gears and lock up the servo.
