Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
y harness on channel 7
Old 03-24-2011, 05:45 AM
husker
Default y harness on channel 7
can Channel 7 be used as the second rudder servo using a y harness? I need 2 channels for aileron 1 channel for throttle 2 channels for elevator and 2 channels for rudder. Did not know if you could plug the battery in channel 7 and still use it. Using Aurora 9 and seven channel receiver. Maybe I need to buy the 9 channel receiver.
Old 03-24-2011, 05:49 AM
BarracudaHockey
BarracudaHockey's Avatar
Default RE: y harness on channel 7
If you use a Y harness you don't use another channel, or you plug them into separate channels and mix them electronically.
You can plug the battery into any open slot on the reciever, or run a Y harness with the battery and a servo.
