flaperons
flaperons
I would like to use flaperons on Giant Super Sportster. Ch 1 aileron Ch 2 elevator Ch 3 throttle Ch4 Rudder Ch 5 aileron 2 Ch 6 elevator 2. I am sure it is in the manual and I am just missing the info. would like to use one of the slider switches to control the flaperons. the radio is the Aurora 9 which I like very much. Am using dual rates and expo. thanks
IL
RE: flaperons
What I would do is go to the "Channel" menu and select a channel that you aren't using. Let's say channel 7 isn't used for anything. Make that a "Flap" and select the switch to LS (Left Slider) or RS (Right Slider). I believe when you make a channel a "flap" it is LS by default. Now go to you P-mix Menu. Now set up a mix for
Flap->Aileron1
And another to
Flap-> Aileron2.
Note: You Probably won't want a 100% mix because it might overdrive your servo if flaperons are down and you make a hard turn. Start with 40% and see what you get. good luck!!
Flap->Aileron1
And another to
Flap-> Aileron2.
