programming aurora for delta vortex
CT
hello. i'm hoping you can help me with a programming issue. i have been trying to program my hitec aurora for a bruce thorpe vortex airplane. this plane is a delta configeration . it has two elevons that act as elevators and ailerons . it has 2 verical stabilizers with rudders. it also is a tri gear ( has nose wheel ). this plane is giving me headaches in trying to program it!!!
functions are: elevons, two rudders which must be in sync,also rudders must deploy out to act as speed brakes on landing, a steerable and adjustable nose wheel in sync with rudders must also be programmed. finally, throttle.
if you would help me with a program that can do all this , it would be very much appreciated.
thanks .
peter
thanks .
peter
RE: programming aurora for delta vortex
ORIGINAL: peter baldino hello. i'm hoping you can help me with a programming issue. i have been trying to program my hitec aurora for a bruce thorpe vortex airplane. this plane is a delta configeration . it has two elevons that act as elevators and ailerons . it has 2 verical stabilizers with rudders. it also is a tri gear ( has nose wheel ). this plane is giving me headaches in trying to program it!!! functions are: elevons, two rudders which must be in sync,also rudders must deploy out to act as speed brakes on landing, a steerable and adjustable nose wheel in sync with rudders must also be programmed. finally, throttle. if you would help me with a program that can do all this , it would be very much appreciated. thanks . peter
. Stryker F29Q with Dual Rudder Airbrakes (Proportional & On/Off).
Also suitable for the MPX Twinjet, MPX Funjet, SkyArtec/HK Funjet and other Delta or Flying Wing.
additional reference:
. Aurora 9 - Delta Wing - set up EPA, D/R & EXP w/photos
. Aurora 9 - Elevon, Ailevator & Taileron - Set up.
ex
Aurora 9 - Template Index: Acro, Glider, Helicopter, Rock Crawler, Tanks, Simulator, as a guide.
Note entire set up then start from scratchin need as addition of retracts should be included in the intial model setup.
Adding retractsto the existing Strykertemplatemay upset other parameters:
Aurora 9 - Programming Problem? - Parameters must be set in correct order e.g. V_tail.
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS Spectra Modules, Optima Transceivers, Minima Receivers & Telemetry
- FAQ & Undocumented Features
- Mixes, Setups,Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
