Optima 7 vs Minima 6T
Sorry for hitting the return before I got the message in. Need to find out what the range differences between an Optima 7 and a Minima 6T. The Optima will not fit, and need to use a smaller receiver. Thanks.
RE: Optima 7 vs Minima 6T
ORIGINAL: jrlingrel Sorry for hitting the return before I got the message in.
Aurora 9, AFHSS 2.4Ghz Module, Transceivers_Receivers & Telemetry
- FAQ, Setups & Tips:
"2.4Ghz Antenna: Transmitter & Receiver Boda and non Boda Installation and Orientation
. Antenna Orientation for best 2.4Ghz Reception - Transmitter Antenna & Receiver Antenna.
. Optima Transceivers, Maxima & Minima Receivers - Installation of Receiver & BODA Antenna
...Pictorial FAQ with Range Test Results. {Regularly Updated with Q&A}"
Full range as above and attached
Alan Tong.
