Aurora A9X - Optic (Spectra Module) Buddy
Hi Straight off the bat I havent even tried to see if it will work.
Is it possible to use a optic 6 and Aurora A9x as a buddy system?
Either way?
Prboz
Either way?
Prboz
Yes, you would need the correct Hitec trainer cable but it will work.
HITEC TRAINER CORD W/ DIN JACK ADAPTER - WEEKENDER WAREHOUSE
You should be able to use either or as the master transmitter. If you can't get the Optic 6 to work as the master, then you might only be able to use the Aurora 9X as the master.
