flash 5x mixing help
i have the flash 5x. i also have a full house sailplane with 6 servos (2x flaps, 2x ailerons, rudder, elevator). i was wondering if i can use all these features with my flash 5x? if not can I use a y-cable on flaps or ailerons, or both?
also how do i set this up??
finally if i cannot use all these features, can i at least for now, somehow get flaperons??
please let me know.
thanks!!!
please let me know.
thanks!!!
RE: flash 5x mixing help
You won't be able to set up a full house sailplane swith the Flash 5, you would need the Eclipse for that.
You can get flapperons using channels 1&5 in the GLID/ACRO mode.
Mike.
Mike.
will the flaperons be availible on the throttle stick?
also, can i mix elevator into the flaperons?
and one last question, even with a y-cable on the aileron servos and the flap servos, i still can't use the flash 5x for the plane (with elevator compensation for flaps)?
You'll need to be in the GLID mode for elevator compensation. I would give our customer service a call to discuss programing; it's too difficult to properly explain it over the forum. (858)748-6948
Mike.
Mike.
