dead band settings on hitec 5945 servos
I'm using (3) hitec 5945s in each wing panel on a 40% extra. I've set the center point and end points with the programmer so that all 3 servos are in synch, but am unsure of what to program the dead bands at. Any help?
Jerry
Jerry
RE: dead band settings on hitec 5945 servos
Ok...I'll leave them all at the same setting, but the setting go from 1 to 15?, I understand that the tightest setting is 1, but with 3 servos on each channel there's lots and lots of buzzing. I set them now to 5. Does that sound reasonable
Jerry
Jerry
You should not have to change the deadband if they are ganged properly. Go here and check out the video(s) on matching/ganging servos http://www.downonthedeck.com/videos_instruction.htm
Mike.
Mike.
