Gear sets HS-85BB Vs HS-85 MG
I have Hitec servos HS 85 BB (plastic gears) , and I want to convert them to metal gear by using the gear set for HS-85MG instead
can I just go straight and use the metal gear set ?, will they fit in my HS 85BB?
Thanks in advance for the help provided
Regards
Niche
The centre pin of the three gear columns rips the plastic housing hole causing the gears to tilt and buzz. Fixing this hole nicely is impossible but if you're desperate try melting the plastic around the pin with a hot screwdriver to give the pin some purchase, but don't make it lumpy. Otherwise, Hitec HS-BB servos are way too weak for what you need. Buy servos that have been tested to have a higher holding torque rating. Loose pins holding the gears in place is a ridiculous mounting method, but its what all the hobby servo manufacturers seem to do
