Servo General question
AL
How are servo load ratings calculated?
Calculations based on motor size and type?
Load the motor by itself can pull or push using a maasuring fixture of some sort?
Push or pull load based on a servo arm hole?
If that then the inner most hole or outer most hole. Yes I know, just curious where the measure; of say 80oz; is based.
If rated 80 oz what loads with a solid rod push pull system.
I am bulding the largest 3-D plane I have ever bought and my servo's exceed mfg. recomendations.....rods too
Just curious where that load rating comes from. Figure I ought to know this.
If I use long arms on the outside hole..... How much is lost.
Cheers
Blue
Cheers
Blue
