Buddy boxing an eclipse 7 to an optic 6
ME
RE: Buddy boxing an eclipse 7 to an optic 6
Yes.. I've asked this question myself. I was assured it would work and it does. I have the E76 and an O6 myself. You need a round to round Futaba or Hitec cord. You must set trims in both radios the same. You must remove the module from the slave tansmitter. If you do not remove the students module both radios will try to transmit. I missed this part the first time I fired up my foamie. No control, all jitters. The reason is that the master transmitter powers BOTH transmitters ! I think battery run time will be drastically shortened. I only ran for about 10 to 12 minutes like this ,at work. I've only done it this one time so far. I don't like having to remove a module when there has been so much brouhaha about bad connections on the Optic 6. I have a question in to MGLAVIN as to whether there is a buddy box for the Hitec system. Hey any of you guys that don't want your Optic 6 anymore I'll pay freight here to use it as a buddy box!
Banned
The student's transmitter won't radiate a signal when it's used in a buddy-box. I buddy-box people all the time on my O6/E7 setup and never bother pulling the module, it makes no difference -- that's a great feature of the Hitec system.
Of course this only applies if you're using a proper Hitec buddy-box cord -- if you use something else then all bets are off :-)
I've found that If I don't remove the module, then I need to have the model set up on both "transmitters" regardless of which one is being used as a slave. Either way - it certainly does work. (But I still don't like the weak cases on the Optic 6's).
In all buddy box /Trainer systems, the student box must be set up so as duplicate the controls of the Master (Instructor's TX). Before training is commenced, when the trainer lever on Master TX is puilled (or button depressed) all functions on model must remain unchanged. i.e.. elevator up = elevator up with trims adjusted so no movement is seen.
Other RC systems also use the 6 pin DIN connector for Trainer/PC interface systems. Hitec is compatible with Futaba provided that only the Hitec One Way Trainer Cord is used and even then some minor smoke could be emitted from the first edition Futaba 8UAP's trainer board. (easy fix). At no time may the Futaba cord be used between two Hitec TX unless Xtal or module is removed from the "Buddy Box" and at no time may the switch on the "Buddy Box" be turned on as the Futaba cable is "open" at both ends. This information has been well documented on Hitec RCD USA and leading Hitec retailers web pages as well as leading newsgroups for a long time.
Direct link = http://www.hitecrcd.com/Support/TrainerCordWarning.htm
Whilst not on the Futaba buddy cable, all leading Futaba simulator interfaces short out pins 4 & 5 (as on Hitec trainer cable) to prevent erroneous RF transmission.
Further details under "Buddy Boxes. Servo Leads. Flight Simulator & Interface." on my web page.
regards
Alan T.
regards
Alan T.
ORIGINAL: aramsdell A.T. Does Hitec make a real buddy box or must we use a 2nd xmtr in it's place ?
regards
Alan T.
