Electron 6 Antenna length
Hitec,
I got an electron 6 with a heli I bought, but the previous owner cut the antenna and put a base loaded one on. I would like to go back to the original antenna length but I don't know how long it's supposed to be. Can you tell me?
schu
schu
RE: Electron 6 Antenna length
ORIGINAL: akschu Hitec, I got an electron 6 with a heli I bought, but the previous owner cut the antenna and put a base loaded one on. I would like to go back to the original antenna length but I don't know how long it's supposed to be. Can you tell me? schu
For reference:
Hitec #58011 Receiver antenna = Black Antenna (aerial) wire & doubler for aircraft receivers, which measures 106cm (41.75 inches) from pre-tinned tip to end, as shown Black Antenna (aerial) wire & doubler for aircraft receivers
#58011 is used for all Hitec RCD airborne RX, irrespective of frequency, except the HFS-05MS which is shorter at 60 CM (23 5/8 inches).
see also
#54001 Green for use with Feather 4CH receiver [lighter wire than #58011 but still 106 cm (41.75 inches)]
#54002 Red Antenna (aerial) Wire, with doubler, for Regular Surface Receiver which measures 61 CM (24 inches) as now fitted to current 27, 29 & 40 mHz surface receivers with the exception of the HIS-03MK IPD receiver which has an antenna length of only 43 cm (17 inches).
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
CA
ORIGINAL: akschu
Hitec,
schu
Hitec,
schu
Hello Akschu.
A.T. is correct about the length of the Antenna.
Thank you A.T.
