Optic 6 page 22 sub manual
YT, CANADA
I wanted to use elevators option ( option to use 2 servo's for the elevators ) and on page 22 of the sub manual it reads that you can use channels 1256 and as I have retracts on 5 I need to use 6 but that channel does not show so that I can slave to 2..... what am I missing?
YT, CANADA
RE: Optic 6 page 22 sub manual
[X(] OK have it now
Setting Up the Ailevator Function
1. This function requires two elevator servos, one for each side.
Plug the right elevator servo into channel 2, and the second
elevator servo into channel 5. If you need retracts, you will
have to use the output from channel 6.
I have to move the retracts onto channel 6 and use the slider for the switch then I can use 5 DOH!
