Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
Aurora 9 flaperon set up
Reply
Old 11-12-2009, 01:48 PM
CSpierings
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Aurora 9 flaperon set up
I am starting to work on programming my first plane into the A9 and I want to set it up with flaperons as it does in my other radios. I have used the Acro mode and the indicated the plane has 2 aileron servos. The channels being 1 and 5 per the instructions for dual aileron servos.
What is the recommended approach for programming flaperons? Do I use a PMIX and slave the channels? I am thinking that isn't the case because I already told the TX to use Ch 5 for the other aileron servo.
CSpierings is offline
Old 11-12-2009, 08:36 PM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Aurora 9 flaperon set up
Quote:
ORIGINAL: CSpierings I am starting to work on programming my first plane into the A9 and I want to set it up with flaperons as it does in my other radios. I have used the Acro mode and the indicated the plane has 2 aileron servos. The channels being 1 and 5 per the instructions for dual aileron servos. What is the recommended approach for programming flaperons? Do I use a PMIX and slave the channels? I am thinking that isn't the case because I already told the TX to use Ch 5 for the other aileron servo.Thanks
Depending on what you select, the radio will automatically optimize the functions for your choices.
In other words, if you select a wing type without flaps, there will be no flap function control.
Note options in that model memories programming.
1. Select "System Settings" > "MDLType"> Wing = "2AILE".
User will note Ch1 AILE:J1 Ch5 AIL2:J1 is preset when checked on the Channel menu.
2. Enter Model menu 2/2 select "FLAP CON" > Select "NULL" > select which switch you desire (e.g. "G") flaps to be on.
3. Return one screen, and set amount of flap control required for each of the two servos, say reduce from 100% (no movement) to 60% - 70% for both. User can also mix in "ELEV: 0%", increasing the "0" as desired.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline
Old 01-10-2010, 05:43 PM
jd391
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How about flaps and flaperons......2AILE & 2FLAP. Can't seem to get second flap to work. I'm sure it's me but could use a little help.
Jim D
jd391 is offline
Old 01-10-2010, 07:30 PM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jd391 How about flaps and flaperons......2AILE & 2FLAP. Can't seem to get second flap to work. I'm sure it's me but could use a little help. Thanks Jim D
Aurora A9 - Flapperon - Set up Flaps and for 2Aile & 2Flap =
Select "[Model Type]"> "WingType" > "2AILE+2FLAP" >"Set">[Tail Type] "Normal" . > "Set" > [Engine Type] > [Single Engine] > "Set" > [Retracts] Y/N >"Set" .[Airbrake] Y/N > "Set"[Fuel Mixture] > Y/N > [Channel Function] >
shows Ch1 & Ch5 = Aile: J1 & J1 (Stick one)
.........Ch6 & Ch7 = Flap & FLP2: LS (Left Slider)
[Sure? select Y/N]
Turn TX Off then Reboot, turn RX On
Checked AOK..
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {frequently updated}
Regards
Alan T.
A.T. is offline
Old 01-10-2010, 09:14 PM
jd391
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes that works great, but is there a way to add flapperons to the mix.
Thanks again
Jim D
jd391 is offline
Old 01-10-2010, 10:29 PM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jd391 Yes that works great, but is there a way to add flapperons to the mix.
Thanks again Jim D
Please advise exactly whatset up is required.
Read "2AILE & 2FLAP" as being one aileron and one flap servo per wing which usually means the outer two servos are ailerons and the inner two are flaps which canalter position - positive <> negative.
Flapperons refer to one aileron per wing functioning as both ailerons on J1 and flaps (slider on Aurora/Optic 6. or on a rotary knob TX such as Eclipse)
Perhaps flaps mixed with ailerons so each combined surface is also an aileron?
1. Enter settings > Model> P.Mixes>Aileron-Flap1>select> enter %rate required for left & Right movement.
2. Enter settings > Model> P.Mixes>Aileron-Flap2>select> enter %rate required for left & Right movement.
(each flap servo, asdisplayed by numbers on screen,requires own P.Mix)
Regards
Alan T.
A.T. is offline
Old 01-11-2010, 09:52 AM
jd391
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Alan
I am trying to emulate a full scale Beaver where the flaps and flapperons work in conjunction with each other.
The flaps are on a three position switch with servos slowed to three seconds with the last position being full flap.
It is this last position where I want the ailerons to drop to flapperon position just like the real deal. I'm sure it's
possible with this TX but I'm not sure I'm smart enough to figure out the mix.
I do appreciate your time
Jim D
jd391 is offline
Old 01-12-2010, 05:49 AM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jd391 Hi Alan I am trying to emulate a full scale Beaver where the flaps and flapperons work in conjunction with each other. The flaps are on a three position switch with servos slowed to three seconds with the last position being full flap. It is this last position where I want the ailerons to drop to flapperon position just like the real deal. I'm sure it's possible with this TX but I'm not sure I'm smart enough to figure out the mix. I do appreciate your time Thanks Jim D
Aurora A9 - Set up Flaps for 2Aile & 2Flap with Flapperon for Scale Beaver.
Refer to attached pictorial guide added 17Jan09 or:
Ch6 = Flap : LS (highlight LS) > "SEL" > amend to "E"
Ch7 = FLP2: LS (highlight LS) > "SEL" > amend to "E"
[Sure? select Y/N]
Turn TX Off then Reboot and test above as basic settings
Do not use [AIL-FLP] under Settings>Model screen 1 as that does not provide for servo time setting.
1. Enter settings > [FLT.COND] > [COND-2] > set. Select time "0" and adjust with up arrow to 3.0.
. Move switch to forward position and change OFF TO ON.
2. Enter settings > Model> P.Mixes>FLAP > AILE >select. Move switch “E” to forward position.
. tap “Rate” and “+” to increase to 100% rate or as required for left & Right movement.
. Select switch E and change “ON” to the forward position return and Tap ”C” to change to “S”.
3. Enter settings > Model> P.Mixes>FLP2 > AILE >select. Move switch “E” to forward position.
4. Enter settings > [S.Speed]
a) tap AILE to highlight L & R, use “+” to increase to 3.0 if slow speed required both going up and down or just “L” if slow down only.
b) tap AIL2 to highlight L & R, use “+” to increase to 3.0 if slow speed required both going up and down or just “L” if slow down only. Tap “C” to change to “S”.
c) Tap ½ to enter 2nd screen and select switch “E’. Tap “NORMAL” top left of screen to change to “[Cond-2]”
5. Enter [Cond-2] and set Speed : 3.0
Controls then operate as understood for Scale Beaver
Double check EPA's to ensure full flap does not bind aileron servos.
Regards
Alan T.
File Type: pdf
A.T. is offline
Old 01-12-2010, 04:57 PM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[deleted - duplicated post #8 amendments)
A.T. is offline
Old 01-12-2010, 10:27 PM
jd391
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Alan
You are real close, but flaps are moving with ailerons.
sequence shoud be:
switch e
position 1 normal flight
position 2 partial flaps
position 3 full flaps and flapperons
flaps need to stationary in all three positions
Thanks again
Jim D
jd391 is offline
Old 01-13-2010, 05:27 AM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jd391 Alan You are real close, but flaps are moving with ailerons.
sequence shoud be: switch e
position 3 full flaps and flapperons - flaps need to stationary in all three positions Thanks again
Jim D
Ah that was much easier than trying to set up full length ailerons mixed with flapperons as was my original understanding, please check amended post #8, even ailerons keep proper speed whilst lowering as flaps...
regards
Alan T.
A.T. is offline
Old 01-14-2010, 08:41 PM
jd391
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Alan
I installed this mix three times and still have a problem with channel five.
If you go to monitor and watch chanel five when you hold hard right ailiron
and switch E from 2nd to 3rd position you will see what I mean. Channel 5
moves in the delayed motion. Maybe I am missing something in the setup.
Jim D
jd391 is offline
Old 01-14-2010, 09:33 PM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: jd391 Alan I installed this mix three times and still have a problem with channel five.
If you go to monitor and watch chanel five when you hold hard right ailiron and switch E from 2nd to 3rd position you will see what I mean. Channel 5 moves in the delayed motion. Maybe I am missing something in the setup. Thanks Jim D
1. TXon - Select >Settings>[Channel] and check Ch1:AILE = J1, Ch2: Elev = J3, Ch3:Thro = J2, Ch4: Rudd= J4, Ch 5 Ail2 = J1, Ch6 = Flap = E, Ch 7:Flp2 = E. Ch8: Aux1 = Null, Ch9:Aux2 = Null. or amend as necessary.
2.With settings provided post #8,
J1 controls both Ailerons if plugged into Receiver slots 1 & 5.
"E" in forward position only also controls both ailerons,on which command both aileronsdroopslowly togetheras flaps, yet retain full aileron responses.
When "E" is flicked back to middle or rear position, the two ailerons immediately revert to normal aileron position without delay.
3. The two flap servos must be plugged into receiver channels 6 and 7 with both flaps up when "E" is rearward. The twoflapsdrop in two stages (as set) say 50 % when "E: is in middle position and Fully down when "E" is in forward positon withoutdelays.
(Above tested with standardHitec servos -used digitals may need to be reset to factory default.)
regards
Alan.
A.T. is offline
Old 01-16-2010, 08:15 PM
griesel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Alan ( way way south of Tucson )
I have a electric Modeltech Magic with 5 servos.
Chl 1 R aileron
Ch 2 Elevator
Ch 3 Throttle ESC
Ch 4 Rudder
Ch 5 L aileron
Ch 6 not used
Ch 7 Tail wheel steering - Battery
I would like to use switch E to do the following:
Down position: Ailerons normal 0 degrees
Middle position Ailerons up + 7 degrees
Upper position Ailerons up +14 degrees
This gives two positions for stable landings with a higher angle of attack for
no bounce and less floating landings.
I have it programmed now, using camber, for:
Down position 0 degrees
Middle position 0 degrees
Upper position +7 degrees
I just am having a hard time getting 3 positions like I have with my
7202's and DX7.
griesel is offline
Old 03-12-2010, 06:52 AM
dmaaero
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As per post #2 that worked pefect for flaprons, could you please add a simple way to achive 3 second delay to flaprons?
dmaaero is offline
Old 03-13-2010, 08:17 PM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: dmaaero As per post #2 that worked pefect for flaprons, could you please add a simple way to achive 3 second delay to flaprons?
Update to post #2,
"Depending on what you select, the radio will automatically optimize the functions for your choices.
2. Enter Model menu 2/2 select "FLAP CON" > (defaults to LS). If a switch is preferred, select "NULL" > select which switch you desire (e.g. "G").
NB: When using two aileron servos in flapperon mode, servo speed can not be adjusted for the flaps without also impacting on the speed at which the ailerons move (slow ailerons not recommended). If slow flap speed required, then usedefault setting with Flaps assigned to the Left Slider (or transfer to Right Slider) and increase/decrease flaps at required speed manually.
Regards
Alan T.
A.T. is offline
Old 03-13-2010, 09:23 PM
griesel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
With JR 7202's and Spektrum DX7 ( they have almost identical software ) I can get 3 settings
of spoilerons / flaperons with a 3 position switch. How is this done with the Aurora 9?????
I have connected the camber up to the slider switch, but disconnected it due to my accidentally
bumping the switch causing disruptions in flight. So I much prefer a three position switch.
griesel is offline
Old 03-13-2010, 10:12 PM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: griesel With JR 7202's and Spektrum DX7 ( they have almost identical software ) I can get 3 settings of spoilerons / flaperons with a 3 position switch. How is this done with the Aurora 9?????
I should have qualifiedthe above post related to trials under Acro, will re-check under Glider mode later today, together with your 3 position switch, and revert if anything different found.
Aurora A9 - Slider DIY Centre Detente (Notch) Slider - two notches in the sliderwould assist maintain 3position locations with the slider.
Some very good tips and screen shots at
Aurora A9 - DLG Set up guide with many screen shots for setting Camber, P.Mixes, Flap Control etc *
regards
Alan T.
A.T. is offline
Old 12-30-2012, 08:00 PM
Enticer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: A.T.
Update to post #2,
''Depending on what you select, the radio will automatically optimize the functions for your choices.
1. Select ''System Settings'' > ''MDLType''> Wing = ''2AILE''.
2. Enter Model menu 2/2 select ''FLAP CON'' > (defaults to LS). If a switch is preferred, select ''NULL'' > select which switch you desire (e.g. ''G'').
3. Return one screen, and set amount of flap control required for each of the two servos, say reduce from 100% (no movement) to 60% - 70% for both. User can also mix in ''ELEV: 0%'', increasing the ''0'' as desired.
NB: When using two aileron servos in flapperon mode, servo speed can not be adjusted for the flaps without also impacting on the speed at which the ailerons move (slow ailerons not recommended). If slow flap speed required, then use default setting with Flaps assigned to the Left Slider (or transfer to Right Slider) and increase/decrease flaps at required speed manually.
Regards
Alan T.
When I enter the flap con menu on my A9 I don't have the option of selecting either of the slider's for flap control. I want to operate flaps on a Beaver with the LS and at the same time have some down elevator mixed in. I can get it working on a 3 way switch "E" but want it on the slider.
Enticer is offline
Old 12-30-2012, 08:21 PM
A.T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Enticer When I enter the flap con menu on my A9 I don't have the option of selecting either of the slider's for flap control. I want to operate flaps on a Beaver with the LS and at the same time have some down elevator mixed in.
Unable to test tonight, but user should be able to select swtich or slider from the channel menu, given setup was in correct order:
. Aurora 9 - Programming Problem? - Parameters must be set in correct ordere.g. V_tail, see chart.
Alan T.
A.T. is offline
Old 12-31-2012, 04:49 AM
Enticer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can select LS for the flaps in the channel menu but then the flaps will only operate if the Flap Con menu is inhibited. If I select NULL for flaps in the channel menu then I can activate Flap Con and get everything working with elevator mix on switch A to G, no slider option.
Enticer is offline
Reply
Display Modes
