Aurora 9 Throttle Up - Throttle Curve
My default throttle setup is that the engine will quit when I have the throttle stick all the way back. I set a Throttle Up point that is say 30% and put it on a switch so I an turn it on while flying. Don't want the engine to quit while flying. I put in a throttle curve. With the Throttle Up inhibited, the throttle curve works as it should. With the Throttle Up activated, my throttle will close between points 1 and 2 and then start opening up. How can I have the throttle curve work as it should between the Throttle Up position and full throttle? I can't see any way to do it. Thanks.
