Aurora Programing
RE: Aurora Programing
ORIGINAL: Mach1Latus Is there a way that I can mix ruder to elevator and adjust the mix % in flight? Thanks Stephen
"You can use the CAMBMIX function assigned to J4 and then use the Adjust Function setting to adjust the mix in flight. - Mike"
regards
Alan T.
