Savage Flux HP
RE: Savage Flux HP
ORIGINAL: KID_EVIL!
If any of you had friends you wouldn't have to come on here to make enemies!
Hows that for a thought of the day?
RE: Savage Flux HP
ORIGINAL: HJJFFFAA
Most common culprit would be binding in the drivetrain.
IL
RE: Savage Flux HP
ORIGINAL: steed2
note to everyone else. this is the most UNCOMMOM culprit.
ORIGINAL: HJJFFFAA
NJ
RE: Savage Flux HP
ORIGINAL: steed2
ORIGINAL: HJJFFFAA
#31
RE: Savage Flux HP
Well first I would say would be the batteries not producing the proper amps the motor or esc needs. So make sure u get a set of batteries with at least a 25c rating higher is always safer. I'm sure binding in the drive train could be a possibility I wouldn't dissreguard it. Then i would look at the weight of the truck u put some big Joe's on there or other heavy tires and alot of aluminum and u have an 18 lb truck that's going to cause some problems. Just keep the weight down and get some good batteries with a good c rating (25c minimum) u should be good. Hope this helps I posted this with phone sorry for any missed spelled words
