Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Monster Trucks > HPI Monster Truck Forum
Reload this Page >
Problem removing alum. servo horn from servo head.
HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
Old 09-24-2010, 09:38 AM
brio
brio's Avatar
Default Problem removing alum. servo horn from servo head.
I'm trying to remove an alum. servo horn from my Hitec HS-7955TG servo and it's not moving.(It's the correct sizeservo horn-incase anyone's wondering)It was a tight fit when Iinstalled and Idid put a little thread-lock on the screw(I was able to remove the screw easily). I don't want to get too rough with it so as not to damage the servo cuz it's an expensive one. Any ideas?
Old 09-24-2010, 12:53 PM
bao
Default RE: Problem removing alum. servo horn from servo head.
if it has a slot (where you put the screw) you could take a small flat head screwdriver and wedge it in the slot, this should help getting the horn off.
Old 09-24-2010, 02:34 PM
sharkattack99
try a small flat head and work under the horn (bottom of it) all the way around the horn but gently see if that helps.
Old 10-21-2010, 09:02 PM
expo
My Feedback: (20)
expo's Avatar
I use a soldering gun to loosen connections. Touch the hot tip gingerly to heat it up then pry on it. Not on a nylon shaft though.
Old 10-21-2010, 09:45 PM
etivac13
etivac13's Avatar
i used a flat screwdriver when i removed mine... and i did scratch the body
Old 10-22-2010, 08:58 AM
brio
brio's Avatar
Thanks for all the suggestions guys. Iactually used Sharkattack99's method about a week ago, being vfery carefuland it worked well. Thanks again.
