HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
Mickey Moust throttle return spring attachment
Reply
Old 10-30-2010, 09:38 AM
expo
expo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Mickey Moust throttle return spring attachment
HPI Savage xl 5.9.
During breakin my thottle went to full and I found the throttle return spring flopping free. I couldn't find out where it was supposed to be attached so I called HPI tech and they told me it clipped on the carb needle fitting just under the fuel inlet nipple. It looked like an afterthought where it went on but I reattached it and it fell off again. Bending it....same thing. I finally took some fine wire and wrapped it around the fitting and through a spring loop. I can't believe they didn't put a ring loop to hold the spring.
Have any of you experienced this and found a more permanent solution?
expo is offline
Old 10-31-2010, 02:07 AM
wolfie1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Mickey Moust throttle return spring attachment
take it off throw it in the bin/spare parts box and fit a failsafe, the spring i found stopped giving you full throttle
wolfie1 is offline
Old 10-31-2010, 10:02 PM
PrjctStrtFrce
PrjctStrtFrce's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: wolfie1
Yes and no. The stock servo also limits the ability of pulling the resistance of the spring, a Hitec985MG fixed that for me. Overkill, but I like the quick and solid power of the servo for throttle and brake.
PrjctStrtFrce is offline
Old 11-01-2010, 04:56 PM
wolfie1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i put good quality 10.5kg servos as my throttle servos when the stock ones finally give up
wolfie1 is offline
Old 11-02-2010, 08:05 AM
Shenanigans
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I dont use a spring either...my spring kept my carb from closing back to idle on its own...id have to hit brake before it would fully close.  It would hang up on the dust boot.  You can drill a small hole in the tvp to hook the spring to....I tried that as a fix for awhile, but eventually decided to take it off.
Shenanigans is offline
Reply
Display Modes
