Dynamyte 086
ME
Dynamyte 086
I was thinking about getting the Dynamyte 086 pipe, but then I noticed that the pipe seemingly comes in only a left-exhaust version. IS there a right exhaust version that works with the Savage? I've heard of people using this pipe with a Savage, so I know it works... but how?
ME
RE: Dynamyte 086
hmm. Elaborate on that please. The pressure fitting would be at the bottom of the Savage though... would that be a problem?
And wouldn't the header need extended TVPs to fit, the stock one is bent at a really weird angle so it won't brush the shocks.
Pictures of your 086 Savage's assembely would be worth about a million words.
ME
RE: Dynamyte 086
Thunder, that's NOT a Dynamite 086. If it was then the pressure tap would be at the bottom of the pipe...... Is that okay?
If I get a 086 and can't mount it, I blame you! :P XD
ME
RE: Dynamyte 086
o.0 So it doesn't matter! Yay!
Well I'm getting that one. One more thing (not neccissarily too you but to anyone) is that the new header might not fit, noting how the stock one is bent like that to avoid scraping the shocks. So basically, the question is a yes or no to your average rear exhaust header fitting on a normal stock Savage without scraping the shocks.
ME
RE: Dynamyte 086
BuMp.
Do you need to get a chassis extension to fit new headers? Sorry for the urgency, Christmas is coming up and that's a good excuse to order crap.
OH
RE: Dynamyte 086
Most 1/8 buggy headers won't fit without hitting the shock, and some won't fit without hitting the shock tower.
ThunderbirdJunkie is running an STS header on one truck, and a THS header on the other one, but the Savage pictured only has four shocks, so he can run anything he wants on that one.
ME
RE: Dynamyte 086
Ohhh. So my best bet is to buy some FLM EXT LCG TVPS (mouthful of acronyms) and then I'm set? Got it... I guess that was coming eventually.
KS
RE: Dynamyte 086
1/8th buggy headers will work on the X chassis, but not on the S21 S25 chassis. You can run about anything on an XL.
An X with a stock Picco 28 and an 086 pipe.....
http://www.youtube.com/watch?v=c3VAeFc7_uw
..... is a blast to drive... Glen
ME
RE: Dynamyte 086
What TVPs are you using?
Btw, nice vid, that's the vid that persuaded me to buy a Savage! No kidding!
well, along with the one where he dropped a stocker off progressively higher jumps until something broke...
ME
RE: Dynamyte 086
Flux big bores = $70
$70 = NOT cheap.
I'd rather buy a two speed, or a pipe for that much. I don't exceed the 8 shocks' dampening anyway, because I usually just run it like a buggy with some occasional small jumps. FLM is supposed to be good with customer service, right? So that means if I buy the non extended plates and the pipe doesn't fit, I can just send em back and get the extendeds. But I don't want to kill my wheelieing!!
$70 = NOT cheap.
RE: Dynamyte 086
ORIGINAL: cswtornado
$70 = NOT cheap.
$70 = NOT cheap.
$39.99 = cswtornado not looking real hard
http://cgi.ebay.com/NEW-HPI-SAVAGE-F...item255ee976ff
Flux Big Bore Shocks < FLM TVP's
