bulletproof diffs?
CA
bulletproof diffs?
Iam thinking about putting the bulletproof difs in my savage X4.6 do Ineed to change anything else to run them? Ithought Iheard somewhere Ihave to swap out the axles to if I run them.
IL
RE: bulletproof diffs?
As for the bulletproof, you can just get the ring and pinion gear. You can then use all the same cups, drive dogbones, and axles.
ORIGINAL: 209mark123
I am thinking about putting the bulletproof difs in my savage X 4.6 do I need to change anything else to run them? I thought I heard somewhere I have to swap out the axles to if I run them.
ME
But if you get them off ebay you get a better value, as you get the HD diff shafts and casings for the same price as a BP diff without all that from a store. Just get the ebay ones, and take em apart and install your existing diff cups.
ORIGINAL: cswtornado
ME
Isn't it possible just to swap out the ones that come with the diffs (HD) with the ones he already has? I don't see any issues with that....??
