HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
Dynamite Big Red Monster .28 on my Savage XL 5.9
Reply
Old 05-22-2011, 04:36 PM
ncostes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Dynamite Big Red Monster .28 on my Savage XL 5.9
Bought a used Savage 5.9 XL, engine was blown, would have needed a new piston, sleeve, wrist pin, con rod and OWB, over $100 of stuff. LHS guys sold me a Dynamite .28 Big Red for $139.
I still have the original pipe and header. Broke the engine in today in the truck.
It had nice power, but two things I noticed, and I'm wondering if anyone else is running this engine in their XL can help me out
1. It's loud. Very loud.
2. There is fuel leaking between the engine exhaust port and the header. It really seems like it needs a shorter muffler or something. When the muffler is on the spring, it pushes back some and since only a spring is retaining the header to the engine, it seems to be a poor seal.
For anyone using this engine or something similar what have you done? Do you use another pipe or header? Do you cut the spring and bend it up or make your own?
Someone here recommended a Dynamite or Ofna 086 pipe - I'd definitley like to have this be more quiet, it makes my revo sound like an electric...
Edit: Also - did anyone else using this engine have to file down the bottom right bulge of the backplate to get a good gear mesh? Without filing that plastic down (the thing that bulges around the screw), I couldn't get a decent gear mesh, it was wayyy to tight (couldn't push the engine far enough right).
ncostes is offline
Old 05-22-2011, 05:38 PM
SavagedXXL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Dynamite Big Red Monster .28 on my Savage XL 5.9
ORIGINAL: ncostes
It sounds like you could use a header seal and spring. The spring is probably stretched because the 5.9 case is bigger than the .28. The Dynamite 086 is a significantly quieter than the polished HPI XL pipe, and performs better. It comes with a different header as well, and better on topend than the XL pipe.
SavagedXXL is offline
Old 05-22-2011, 05:54 PM
ncostes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds like a deal on the Dynamite 086 pipe. Maybe its header will work out such that the muffler can seat on the fat steel spring in the front of the chassis without pushing back?
See picture for what I think is the problem now.
Re: header seal - what is that, is that the gasket that came w/the engine that goes between the header and the engine?
A shorter spring (the one that goes around the crankcase) makes sense as well.
ncostes is offline
Old 05-22-2011, 07:29 PM
woodwore69
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I put 2 springs on my headers and if stock holder doesn't work I make a new one out of coat hangers.As far as filing I think you mean the bottom of the roto start yes I have had to file there and the tvps hit the motor mount screws sometimes just file the tvp a little to let them slide by
woodwore69 is offline
Old 05-23-2011, 04:45 PM
ncostes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Figured out my problem was mainly the gasket that comes w/the .28 Dynamite Mach 454 is too small for the stock header. Using the one that came w/the stock engine did the trick.
The gear mesh - was way too tight, the LHS guys sold me a 14T clutch bell which allowed me to set the gear mesh properly. But now I'm not getting into 2nd gear.
What pinion/spur combo are you guys using if you're using a .28 with an XL?
ORIGINAL: woodwore69
ncostes is offline
Old 05-23-2011, 07:04 PM
PrjctStrtFrce
My Feedback: (10)
PrjctStrtFrce's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try the stock 16/52 and then see what you like with the 49, 48, 47 spurs. The lower the spur tooth count, the better the top end and the higher the spur tooth count, the better the low end. Opposite for the clutch bell.
PrjctStrtFrce is offline
Old 05-24-2011, 01:50 PM
dragonbat13
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used the coat hanger trick on my 5.9 with my ofna 086. Will probably try two springs also.
Let us know how the engine works out.
dragonbat13 is offline
Old 05-25-2011, 04:53 PM
ncostes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So far so good, I should have gotten the 15T clutch bell instead of the 14T as that would have been small enough. I looked at getting the 47T spur to get closer to the original gear ration but it's $33!
I think I'm good w/the gearing as it is now, the truck is fast.
LHS ordered a Dynamite 086 pipe + header for me, I'll post if it is quieter than the stock pipe.
Thanks for the tips.
ncostes is offline
Old 05-29-2011, 04:46 PM
PrjctStrtFrce
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Stick with PLASTIC spur gears. They are cheap and very durable, just set the gear mesh properly and they will last a REALLY long time. If you get a steel spur gear, then you are wasting money, adding rotating mass, and if something fails, it will be a combination of the expensive spur gear AND the clutch bell.
Contact Us Archive Advertising Cookie Policy
