HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
another wormy newb question please help!!!!!
Reply
Old 05-25-2011, 01:51 PM
dragonbat13
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default another wormy newb question please help!!!!!
well we finally took the xl out of service
the engine is acting as though the clutch is slipping and not putting power to the wheels.
other than the clutch what other areas should I check out?
I plan on pulling the engine to seal it so I may as well use the time to troubleshoot the problem while I am at it.
Any help would be great, and I would be very thankfull.
dragonbat13 is offline
Old 05-25-2011, 02:32 PM
tallone09
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: another wormy newb question please help!!!!!
Check your spur gear see if it loose.
tallone09 is offline
Old 05-26-2011, 03:24 AM
Umar M
Umar M's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i suggest that you checkout the transmission box, see if the gears inside are in good condition or not, have a look at the spur.
also check the clutch shoes, are they too worn out?
Umar M is offline
Old 05-26-2011, 02:28 PM
MMartinez
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just check the drivetrain starting with the Clutch shoes and im sure you'll find the problem. After all if you're pulling the engine you could use that oppurtunity to check that.
MMartinez is offline
Old 05-29-2011, 04:41 PM
PrjctStrtFrce
My Feedback: (10)
PrjctStrtFrce's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you're doing the motor, then you may as well just take a look at the diffs. Only 6 screws and 2 retainers to get the diff out. Make sure all the screws are there and put some loc-tite on metal to metal screws. I would also recommend putting some ball bearings in place of the plastic bushings in the steering posts. You probably won't notice a difference, but the bearings won't get worn out like the plastic bushings would.
PrjctStrtFrce is offline
Contact Us Archive Advertising Cookie Policy
