Xss Diff
RE: Xss Diff
Yes the X SS diff is the same as the X but the SS has HD drive cups where as the X does not. Meaning the SS is better. the internals are the same too.
RE: Xss Diff
Add the [link=http://store.savagess.com/product_info.php?products_id=394]4 Bevel Gear Diff Conversion[/link] and some lucas motor oil and you will be set for a long long time.
If you want to go for handling go with a 7000 wt oil up front and 5000 out back.
VT
RE: Xss Diff
they do have the 4 gear setup, the differance between the x ss transmission... (Xss vs X 4.6) 17t vented CB vs non vented, 47t steel spur vs 49t plastic, HD shiny dog bones vs standard, and as mentioned before HD diff cups vs regular's
the lug
the lug
TX
RE: Xss Diff
So the Xss diff is better than the X? how come the Xss diff is cheaper than the X in ebay shop shop? is it beacuse the X is more popular? :-)
RE: Xss Diff
The SS comes unasembled ready to put together so it would make the most sense that there sold by themselves rather than in the bulkhead. Honestly the only thing worth the money is the HD cups. That is if your going to keep running X axles. Everything else is identical.
RE: Xss Diff
ORIGINAL: rclugnut10
the lug
the lug
the x has a 47 tooth plastic spur not 49 tooth. the final drive ratio is the same.
