leaking carb
leaking carb
today i noticed something bad,whin i prime my xl fuel literally flows out of the mid range screw,is it normal?if not
what should i do?
ragards
abhishek
what should i do?
ragards
abhishek
RE: leaking carb
The O-ring seals on the screw might be worn out. Try replacing them with fresh ones and clean your engine afterwards. having a clean engine will halp tell weather it is still leaking or not.
