HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
Savage xs wont move??
Reply
Old 09-04-2012, 04:03 PM
209mark123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Savage xs wont move??
Irecently started having this problem my savage xs wont move when Ihit the throttle makes like a grinding noise as its trying to move but it just stutters. Now when Idid pick it up and held it in the air it seemed to work fine. Bad thing is Ioriginally thought it was the motor giving out and bought a new one and it didnt change a thing. Ichecked the pinion gear and transmission gears so all is good there and Iwas in the diffs not more than a week ago and everything was fine. Think it might have something to do with the esc? Idont know any opinions would be appreciated.
209mark123 is offline
Old 09-04-2012, 04:09 PM
mattsauto
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Savage xs wont move??
did you check to see if the slipper nut had backed off? mine does that sometimes.
Quote:
ORIGINAL: 209mark123
mattsauto is offline
Old 09-04-2012, 06:04 PM
t9dragon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds like you have stripped gears in the diffs.
t9dragon is offline
Old 09-04-2012, 06:29 PM
209mark123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another weird part about it is that if Inudge it with my foot it will move under it own power but from a stand still it will just stutter
Old 09-04-2012, 07:26 PM
209mark123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Actually Ijust ripped apart the rear diff and discovered on of the bearings that sit on both sides of the diff on the shafts has totally exploded think this could be the problem forgive me if some of these problems are a little annoying because Ido not have a lot of experience with the diffs themselves.
Old 09-04-2012, 09:42 PM
209mark123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Found the exploded bearing left that diff out turned the car on with the front diff still in and it was still having the same problem. So I took the front diff out and ripped them both apart and all the gears inside are in perfect shape. But with both diffs out the motor spins freely without any hesitation This is really starting to get old...lol I cannot figure out for the life of me whats going on with this thing.
Old 09-08-2012, 03:08 PM
mattsauto
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sounds like either your slipper nut loosed up or the transmission has a stripped gear. did you check the slipper clutch nut?
Old 09-08-2012, 05:49 PM
209mark123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All the gears in the tranny are fine actually, one of the slipper pads looks really worn down so Im changing that to see if it helps. My slipper nut seemed to be tight when Itook it apart so I dont know see if the pad fixes it.
Reply
Display Modes
