If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
  1. #26
    RE: Bad Engine, Decisions
    That is really cool. I will have to do that. I had the spring and pin break on me though even with the stock owb setup. Wouldn't this just wear out the spring rally really fast?
    That's how I roll, Jack
  2. #27
    djyjrlz's Avatar
    Join Date
    Jan 2010
    steyning, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    it does increase rotating mass, but think of the mass of the tires compared to that...almost a negligable in comparison. and i think this is a great solution to a really common problem, great video!
    So glad to have a savage again. Time to make it handle less like a savage.
  3. #28
    PrjctStrtFrce's Avatar
    Join Date
    Aug 2005
    Bartlett, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Rotating mass from the power source is different than rotating mass from the wheels.
    Keep your RCs, get rid of the wife. -bigwaltc-
    SFGP,HPIX4.6,XL,RS4 3,MERV,Kyosho IGT2RS, Redcat Rampage MT V3
  4. #29
    Join Date
    Oct 2008
    pefferlaw, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It does not increase rotating mass on an f 4.6 guys.
    oversteer scares passengers, understeer scares drivers!-savagex,-savagexl,-savageflux,-revo3.3,-tmaxx3.3,-losi aftershock ltd
  5. #30
    Join Date
    Aug 2005
    Bartlett, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    How do you figure?
  6. #31
    Join Date
    Oct 2008
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If your referring to the starting mod in that video on the f4.6, that start shaft doesn't spin when the engine is running. It has a spring and pin mechanism in the end of the crank and once that engine starts there is absolutely not driving force against the start shaft. I have a big block revo with one of these engines that I use the one way bearing in the end of a drill to start. Engine running you can grab that shaft , it's not even spinning. Like I said earlier some engine start shafts are keyed to the crank and yes then this would add mass but not with f series mills.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
