motor change
motor change
I have an older sav.2.5, and would like to know what is the biggest motor I can put into my truck that will compete with the newer big block monster trucks?
RE: motor change
The Savage 25 had a 4.1 CC Big Block engine in it so the newer 4.6 CC engine should be a direct replacement. They generally do not change much as far as the clutch bell fittings and you should be able to bolt it right in using all your other parts.
